Hi all,
Have had a read through the wiki and found it really useful, thanks for that. I just have a few questions before I make some purchases.
Currently have an old analogue system installed with 10 camera's each having there own 12V power supply, wired locally, and coax cable ran from the DVR.
Looking at replacing all of them with IP camera's so will be running Cat 5e to 9 of the existing camera's and using a PoE NVR.
The 10th camera has around a 250m coax cable underneath the ground to a camera at the premises entrance. I want this to be an IP camera so I'm looking at using an ethernet over Coax adapter because rewiring with Cat 5e is out the question. Is there another solution to this?
I'm able to buy HikVision equipment through my company, so getting this brand of equipment shouldn't be an issue.
I'd quite like to keep with just one brand for all the cameras.
Was planning on purchasing the following:
10 x DS-2CD2335FWD-I Hikvision 3MP Turret camera's (Varying Focal Lengths)
1x DS-76161NI-K2/16P Hikvision 16CH NVR
I'm aware quite a lot of the forum is a big fan of Dahua IPC-HDW5231R-ZE, I see from other threads that they have pretty similar performance, does that extra 1MP in the HikVision make that much of a difference? I also presume that the Dahua Starlight will be a lot more versatile due to the varifocal.
Can anyone recommend the equivalent in a Dahua system?
I'd quite like to just keep with an NVR rather than setting up BlueIris.
Does anyone recommend a UK Dahua distributor who works with businesses not involved in the CCTV trade?
I'll be looking at adding additional camera's to the premises as time goes by because after reading the cliff notes, it's obvious that there are flaws in the system which could prevent a positive identification of a suspect in the event of an incident.
