HowD,
Dahua caught my eye because of the AI tech and reputable build quality (and the presumed upkeep of firmware). I found a YouTube review of the IPC-HDW5442TM-AS-LED model and thought that was the one and then I came across a coax camera, 4MP-B180, that had a 1/2.8" Sony STARVIS CMOS with a fixed 2.5mm 180 Degree Fisheye Lens / 172 Degree Effective Range. I thought wow, what if I could find a Dahua panoramic, low light camera that would allow me to decrease network runs. I did a cursory look but I think my past self must have found out they are expensive because nothing was stored in ram. Have you guys come across a solid performer for a field of view of around 170ish (honestly, 270 would be ideal)? I am looking for the latest gen/technology. Any cameras coming out next spring worth waiting for? If not, I may just pull the trigger on the HDW5442TM-AS-LED, the vari-focal version and maybe a front door camera with a speaker/mic to get a feel for them. My brain hurts when I try to understand Dehua's "ai" marketing and PC software. I can't tell if the AI is built into the cameras or the NVR...and why does Dahua have DSS, Smart PSS, and different tiers of IVS (premium, advanced, and analytics+) and now wiz sense? What do you guys like for front doorway that has a speaker and mic? Also, Dahua hardware and either Dahua or BI software will pass the spouse test, right? No issue with push notifications and the mobile software?
Thank you.
Thank you.
