I just took delivery of a DS-2CD3345-I 4MP camera running v5.3.3 (sticker and in the camera) that I can log into, is ML and defaults to English, I can select 2560*1440, etc. I have a Hikvision 7816N-E1 NVR (ML NVR, hacked to default to English) running 3.0.10 with nine 2xx2 3MP cameras all using 5.2.5 streaming 2048*1536. No issues with the setup except when adding the 4MP camera.
The 4MP cameras adds to the NVR properly and everything seems to work except that the NVR won't allow me to choose a Main Stream(Normal) or (Event) above 704*576 and there is no Substream selection (on both the Web and local VGA interface). So it looks like the Main Stream entry is using the Substream. So the live and recorded video isn't very sharp (duh). It seems as if the NVR isn't compatible with the 4MP camera. iVMS4200 will display the 4MP camera, but only the low res stream that it thinks is the MainStream.
Not sure what to do?
-Use Whoslooking downgrader on the 4MP camera to v5.2.5? I don't know if that will brick the camera and if it does I don't have the original hacked English 5.3.3 to restore.
- Update the NVR to higher firmware version? I'm worried as the NVR is definitely Chinese region (Lang=2) and I don't want to lose the English interface (I know to never restore the NVR to default as I believe that will cause issues)
