fenderman
Staff member
- Mar 9, 2014
- 36,891
- 21,409
Yes, but did you disable basic motion detection in the camera? I dont think BI can pull an ivs event since its not passed via onvif. Regardless, blue iris zone crossing is much more sophisticated and customizable vs tripwire...nope, you are looking at my test setting, I used the disarmed state because it doesn't normally do motion detection, I also enabled sending an email on the camera when ivs was triggered so I would know for sure I triggered it, and then I got a push notification from BI with wording from IVS in the camera, the only thing enabled on the cam was "camera's digital input or motion" as seen above. I ate dinner, now I'm about to set up IVS on my dahua cams and disable motion in BI on both of them.
