Looking for advise on best networking set up for adding 4-6 IP cameras and recorder. Current data network set up is as follows:
1) (1) 4 port router connected to (1)16 port gigabit switch (non-POE, non managed).
2) Switch serves (13) RJ-45 jacks in various rooms via individual cat 5e cable runs. Router is located in Office. Network switch, patch panel located in structured wiring panel in closet.
3) IP cameras (POE), cables, etc are not installed.
4) spare older PC (Intel Core 2 quad Q9450, 2.66GHz, 8GB ram) is available if needed.
Desire:
1) Looking for something compact, clean, minimal exposed wiring, etc., that can connect to existing network. Flexible, compatible, expandable, etc. ( I currently have 1 Hikvision IP dome camera, but plan to expand)
Questions:
1) What is recommended recording solution? NVR with built-in POE, NVR without POE, stand-alone recorder PC, or NAS?
2) What is best way to connect cameras and NVR, Recorder PC or NAS to network? Use built in NVR POE or separate POE switch? Options:
a) add separate 8 port POE switch for cameras and feed POE switch from existing 16 port switch. There should be room for adding wiring terminations and 8 port POE switch in panel. (16 port gigabit switch is also in the panel)
b) add separate 8 port POE switch for cameras and feed POE switch from existing router. (router is located in the office cat 5e run which feeds the network switch)
c) wire cameras directly to NVR with built in POE and not use the wiring panel or separate POE switch.
d) connect NVR, Recorder PC or NAS to network switch.
e) connect NVR, Recorder PC or NAS to router.
3) Any advise on hardware? Brand? Options:
a) 8 port POE switch: TRENDnet 8-Port Gigabit GREENnet PoE+ Switch TPE-TG80g, others?
b) NVR: POE/non-POE - ?
c) PC /operating system/ software: - existing spare PC, HP Elitedesk mini, others?
d) NAS: Synology NVR-216, DS216+II, others?
e) other Hardware?
Desire:
Questions:
e) other Hardware?
