- Nov 30, 2017
- 187
- 96
as I plan my cam installation and upgraded network configuration, thoughts of hardware location keeps coming to mind.
Ultimately, I will have 10 - 15 cams. There will be possibly two 8 port POEs to support the cams. On networking side, I will have ubiquiti router and at least two access points. One for the inside, the other in the backyard for back/outside support. Quite possibly a third for the front outside. The cable modem will be moved to whereever all the hardware ends up. I am in southern California area in Los Angeles county. Summer weathers can get at 95 degrees.
My thoughts are to put all this hardware in the garage, installed on a wood board. I am concerned about the heat in the garage. I would prefer NOT to bring all this hardware in the house, not to mention all the ethernet cabling. I also thought about putting it up in the attic but I would think it is even hotter there in comparing to the garage.
There IS one hall closet on the top shelf that could work but with the closet door closed, I have concerns of the heat build up.
Any suggestions/recommendations would awesome.
