I am looking at managed switches to replace my 8 port that is full, and am wondering how much difference it will actually make if I am running a 100mb switch vs a 1gb switch?
Right now, I have the following...
CAT 5E cabling.
4 EmpireTec IPC-Color4K-T180 cameras,
3 EmpireTec IPC-T5442T-ZEB cameras,
and a EmpireTec VT02311R-WP doorbell.
I am sure I will be adding additional cameras, probably
1 or 2 additional IPC-Color4K-T180,
1 or 2 additional IPC-T5442-ZEP cameras,
1 or 2 additional VT02311R-WP doorbells (or similar),
and maybe a 1 or 2 of the Dahau IPC-WL46A cameras
and possibly 1 or 2 of the SD4A425DB-HNY
All of the cameras are on their own network with no outside connection, and only 2 computers on that network (BI machine and the machine I remote into to manage the cameras over HTTP).
So, with what I am looking at for cameras, will a 1gb ethernet switch make a noticeable difference over a 100mb switch?
EDIT:
I thought of a couple of additional questions....
Right now, my cabling is not permanently run, just 2 cables through the wall, each to a splitter () and then runs of 100' or less to each camera.
1. Is Cat5E a good choice for permanent cabling or should I look at 6/6A cabling (the majority of the cable will run through the attic with on small amounts in the weather)?
2. Is it better to run a single larger (more ports) switch, or with multiple fewer port switches daisy chained?
3. For what I listed above, what power requirements should I be looking at for a switch?
Thanks,
Eric
CAT 5E cabling.
EDIT:
Thanks,
Eric
