So, after reading some posts, I thought that I would revisit my network setup. I want to make sure that I have everything set to run efficiently and smooth. So far, I have not experienced any issues with speed or security, but again, I want to ensure all is well. I am relatively inexperienced with networking, so I am sure that this may provide a good laugh to some.
To explain my setup properly, I figured I would bring out these points:
- I have firewall rules in the EdgeRouter X set to where devices within a VLAN cannot communicate with one another or access the router or switch home page. Only the master network/VLAN has that access.
- I have firewall rules in the EdgeRouter X set to prevent separate VLANs from communicating with one another. The only exceptions would be that the master VLAN can access everything, and the VLAN on which the Blue Iris computer sits can access the camera VLAN.
- The BI computer does sit on a different VLAN than the cameras. I decided to do this because I wanted to completely eliminate any chance of the cameras gaining any access to the internet. Since I figured that the BI computer would need access to the internet for updates, push notifications, etc., I decided to separate.
