Hi everyone,
I've attached a photo of what I'm trying to do, which includes the camera models and NVR model I'm working with:
I'm wiring my IPCs myself. I have a plan to get three 3 of the cams into the front end of the house and into my network cabinet in the basement. I also have a plan to get the 3 other cams into the back end of my house in a consolidated area in the basement.
There's an existing ethernet cable running from the network cabinet to the back end of the house. To replace this cable would be hard and probably outside of my skillset. I'd probably need to destroy walls and ceilings. I want to place a POE switch in the back of the house to connect those 3 cams to the NVR.
Here are my questions:
- I'm having a hard time identifying if the cable currently running from the front to the back of the house is Cat5 or Cat5E. It's marked "4/24 (UL) C(UL) CMP/MPP VERIFIED (UL) CAT 5 SEUPERIOR ESSEX 215 9 H" and is probably several years old if not older. I tried googling, but am having a hard time pinpointing the cable type.
- Even if the cable is only Cat5, shouldn't that support 100Mbps? And shouldn't 100Mbps be plenty of bandwidth for those 3 cameras?
- Will my NVR support me sending the signal of 3 cameras to 1 port?
- Will I lose functionality or configurability in any way due to this setup?
