I have the EmpireTech IPC-T5442T-ZE which is the same as the Dahua IPC-HDW5442T-ZE.
I am wondering what Make and Model I should use since I couldn't find an entry for EmpireTech in the Make dropdown, and when choosing Dahau as the Make, was not one of the models listed in the Model dropdown.
I have attached a screen capture of the "Network IP camera configuration" for this camera.
When I did a "Find/Inspect" with no value in the IP Address textbox and the User and Password values entered, the camera was found in the resulting list as:
When I double clicked the entry to do an "Inspect", the result in the "Inspecting..." window was:
My question are...
Eric
IP Address: 192.168.0.230:80,54,1935 (which is the correct IP address, but I don't know if the ports portion is correct).
Opening 192.168.0.230 port 80...
HTTP Get / request...
OK
ONVIF GetSystemDateAndTime
2023-01-17T19:01:51.000Z
Requesting device information...
Manufacturer: General
Model: IPC-T5442T-ZEB
FirmwareVersion: 2.820.15OG001.0.R, Build Date 2021-07-06
GetCapabilities...
Querying services
Has Imaging services: /onvif/imaging_service
Has media services: /onvif/media_service
Has RTP_RTSP_TCP, requesting profiles
profile token MediaProfile00000
profile name MediaProfile_Channel1_MainStream
profile source is 00000
profile source config is 00000
profile token MediaProfile00001
profile name MediaProfile_Channel1_SubStream1
profile token MediaProfile00002
profile name MediaProfile_Channel1_SubStream2
requesting URI for profile MediaProfile00000
RTSP URI: /cam/realmonitor?channel=1&subtype=0&unicast=true&proto=Onvif
requesting URI for profile MediaProfile00001
RTSP URI: /cam/realmonitor?channel=1&subtype=1&unicast=true&proto=Onvif
requesting URI for profile MediaProfile00002
RTSP URI: /cam/realmonitor?channel=1&subtype=2&unicast=true&proto=Onvif
Has Event services: /onvif/event_service
Has WSPullPointSupport
RelayOutputs: 0
InputConnectors: 0
Has Device IO services: /onvif/deviceIO_service
AudioOutputs: 0
Has PTZ service: /onvif/ptz_service
Done
My question are...
1. Since I could not find it in the Make/Model dropdown for either the EmpireTech or a Dahau IPC-HDW5442T-ZE, is this the correct camera "Make" and "Model" or is there a better one to use for this camera?
2. Do the settings look correct?
3. Could the "Network IP camera configuration" settings be the reason that I am seeing multiple "Warning Message" entries in the Status Log with a "Message" of "Events: subscription 00002efd"?
Thanks,Eric
