Network design question regarding the Blue Iris PC and which switch it should use
105437
BIT Beta Team
Jun 8, 2015
2,234
1,087
I have a Ubiquiti Unifi network that consists of a Unifi Dream Machine Pro gateway/router, 24-port switch, 24-port PoE switch and 6-port PoE switch. Currently, I have 14 cameras connected to my 24-port PoE switch. My other 3 cameras are plugged into my 8-port PoE switch that's not in my network rack. The two 24-port switches connect to the UDM Pro via 10 gig SFPs. The 8-port connects to the UDM Pro via RJ45 Cat 6.
My question is, should my BI PC be plugged into the PoE switch with the rest of the cameras? I could plug it into the UDM or other 24-port switch. One thing I've noticed, the BI PC runs a steady 160 Mbps and when I run an internet speed test, I don't get the full 1 gig up/down. This makes sense considering the steady camera bandwidth from the 17 cameras. Currently, the BI PC is connected to the non PoE 24-port switch.
Does it make any difference as far as BI UI3 or mobile app performance which switch I use? Thanks!
It really depends on the logical layout of your network.
If the PC and cameras are all on the same subnet and that subnet is available to all of the switches then it doesn't really matter where on the network you plug the PC in.
Reactions: 105437
Yes, same subnet. I have noticed that other wired devices connected to the same switch as the BI PC do not get 1 gig up/down on the speedtest... if I pause all the cameras, they do.
All of your camera traffic is going via your udm.
This is probably impacting it somewhat.
If you plug the PC into the 24 port Poe switch you will still have 3 cameras going via the udm but you should still notice an improvement.
Reactions: 105437
I'l try connecting the BI PC to the PoE switch Thanks for the suggestions.
Quick question: do have a separate wi-fi router for you IOT network (x.10.x)?
For mine, IoT .10 is only for wired devices and is segregated with rule sets in the router.
Wireless IoT segregation is handled with a VLAN as .20 and then the same rule sets for .10 are applied in the router. Since I don't have a full Ubiquiti system I use VLAN tagging on the AP and then assign that tag to the .20 subnet in the router.
Hopefully that all makes sense.
Thanks. I got an edgerouter x for christmas and have been trying to figure out how to set it up properly.
These are the steps I followed to segregate IoT and any other devices so they can only see the internet.
