Hoping someone can point me in the right direction. Here is my system
Cameras(all connected via wifi):
4 Dlink 5222Lb PTZ
2 Ctronics CITPC-590c PTZ
Head End:
Intel NUC7i5
Ubuntu 22.04
Agent DVR
Routing:
Asus ZenWifi XT8 Base Unit
Asus ZenWifi XT8 Mesh Node 1
Asus AC-RT3100 Mesh Node 2
Internet:
Comcast 1 Gig Cable
Other Devices:
Approximately 50 other various devices such as computers, RPI for storage server control, Alexa devices, etc. 12 or so of these are ethernet and the rest Wifi.
I got Agent DVR setup and functioning mostly as hoped. All was happy. Then, after 48 hours, my network started to have huge congestion issues. Connecting to other devices in network, and getting any kind of internet was very, very slow. I did a speedtest and it was down to around 11 Mbps or so (from its usual 950+). This was true of a device on ethernet as well as wifi. After some troubleshooting, I narrowed it down to the newly added Agent DVR setup. I did some reading, and followed some advice to separate out the cameras and Agent DVR to a different subnet. So my normal network is in the 10.0.0.1 range. I set the cameras and the ethernet card in the NUC to the 10.0.1.1 range (cameras still on the same SSID as everything else). I also set the Wifi in the NUC with a setting in the 10.0.0.1 range(ethernet was 10.0.1.1) so I could communicate with it. I put one computer on the network that happened to have two NIC cards with its second card also on the 10.0.1.1 range so could see/troubleshoot the cameras directly. (the Agent DVR NUC is headless). This functioned but sadly in the same way as previous. Within a day my network was unusable. Immediately after unplugging the NUC, full usability was restored.
Is there a better way? What is dragging my network down so much?
Quick note, as I illustrated in my rough drawing, the cameras are connected to all three of the mesh nodes due to placement around the home.
Open to ideas.
4 Dlink 5222Lb PTZ
Head End:
Intel NUC7i5
Ubuntu 22.04
Agent DVR
Routing:
Internet:
Comcast 1 Gig Cable
Other Devices:
Open to ideas.
