biggen
- May 6, 2018
- 2,929
- 3,369
If you are only getting 100Mbps from that switch then the possibilities are:
1. The laptop/desktop you are performing the speed test from only has a 100Mbps NIC.
2. The switch only has a 100Mbps connection to the upstream router. One of those two pieces of equipment is not seeing the other as a 1Gpbs device.
3. The cable is damaged between the router and the switch.
What does the link light show on the router upstream from the switch? Does it show a 1Gbps connection or 100Mbps?
