Hi
Why is it when I plug the cameras in with the Cat5e cable the equipment came with they autodetect and work great. When I plug the cameras in with a new Cat6 cable (shortest is 10m long and longest 40m, that i've run throughout the house), it either does not work at all, or gives me “Net Error”. The cat6 cable is tested, not broken and new. When i try a short piece of Cat6 (approx 1m long) the cameras will autodetect and work. The lights at the plug port are both on. This is the same for all cameras. The cameras have a power supply plug, i'm thinking maybe it will needed to be powered even tho its POE?
SANNCE® 8CH CCTV NVR System POE 1080P Video Output 2.0M Weatherproof CCTV IP Camera with 2TB (I61DX)
Thank you
Steve
Thank you
Steve
