Need to minimize cabling for IR illuminator
105437
BIT Beta Team
Jun 8, 2015
2,196
1,085
I purchased a Tendelux IR Illuminator that's powered by 12v. This illuminator is going to be mounted along side a Dahua 5231 mounted with a junction box. I have a second PoE ethernet cable run to this location and I'm trying to find the best way to connect it using this cable that uses the least amount of connectors, splitters etc. Is there a streamline way to convert PoE RJ45 to a 12v connector. I have found a splitter that works but it's pretty bulky. I'm trying to avoid another junction box for the IR illuminator. Thanks!
