need to get the latest alert via http
rabittn
Sep 2, 2014
28
7
Trying to pull the latest alert image in as its own camera in another application (Home assistant)
The closest thing i can find is using the url/alerts/@record and possible using the json interface to find the latest alert record number?
Am i missing something simple?
I'm not aware of a simple method to return the latest alert thumbnail.
That’s how I do it.
1) use json to get the record# from the camera ... use the JSON cmd ‘camlist’ and from the result, use key [data][camid][lastalert];
2) use {ip-port}/file/clips/@record#[&session=session] to get the image... ‘&session=session’ may not be necessary
No need for a camlist command for this.
You're right. I should have suggested the more direct json 'alertlist' cmd
[cmd] => alertlist
[camera] => {shortname}
[session] =>xxxx
From the result, use key [data][0][path] ... The latest alert record is always the first one listed in the result, hence the [0].
The value of 'path' is like '@501384001.bvr', and it can be used directly in /file/clips/ HTTP command (i.e., no need to remove the '.bvr)
You can get the alert's thumbnail with /thumbs/path. For example /thumbs/@13891853512.bvr. It is a bit faster and usually more relevant than the first frame of the alert.
Reactions: jaydeel
Thank you for your responses, however they seem to be over my head... I will see if I can come up with what you are saying should work.
Nice.
