You need a seperate POE switch with cams addressed in the 192.168.1.1 scheme.
But you'd need to access every cam you want to change using the current IE method, go to TCP/IP and change DHCP to Static
start with something easy to recall...like 192.168.1.200 and go up....
and a gateway of 192.168.1.1
I have a 4108 NVR from Amcrest....for whatever reason the 10080 port type of connection to the Cams is slow as shit...on this device.
When i moved them to " remote devices" they began opening like normal. Making going in a tweaking the cams much less of a hassle.
