Hello all
Been reading in here for a while, since i am trying to figure out what system is best for me. Hope you are able to help me with my last questions, before i purchase
I want a system for my home. Cameras are going to be placed outside, monitoring entrances to the house and driveway.
I have decided for Hikvision, as i can see they are recommended alot in here.
I need 4 cameras and a NVR.
So far i have found this: http://s.click.aliexpress.com/e/Uw1DHR2
For NVR i have found this from same supplier: http://www.aliexpress.com/item/Hikv...ase-HDMI-and-VGA-Output-At-Up/2047545487.html
I will buy HD + cables local.
Here goes my questions.
1. Does the cameras look ok?
2. Will this NVR work with the cams i selected?
3. Will there be a problem in buying HD + cables local in my own country (Denmark)?
4. Do i need to buy seperate mounts to fit these cams? They are going to be fitted on a brickwall.
5. Do i need any more equipment to have a fully functioning system?
Hope you will help a newbie out here
Thanks
Thanks
