Hi all,
First off - To the experienced guys I am going to apologize in advance for what I am about to ask . If you could have mercy on this noob it would be greatly appreciated
In order to get your cams recognized on your network what is the most common / recommended way of doing so? temporarily change network to same ip range as cams, log into each cam and change it to have the same ip range as network in normal state?
for instance my ipv4 is 192.168.0.17
cams are default 192.168.1.108
So go in change all cams to 192.168.0.XX ?
then once all cams are working make sure the whole deal is behind a VPN and call it good?
Thanks
Thanks
