Hello everybody,
I need some help getting me understand how the whole fiber thing can work for me.
So I have Ip camera setup with a 16channel POE NVR that is connected to my network via ethernet cable and there are about 8 cameras hooked to it each connected to the poe ports on the nvr. Now I have a separate building about 400ft away from my house and I want to install fiber cable into a conduit underground to the separate building to hook up 2 more cameras and maybe later wifi AP.
Now I have already bought a waterproof poe switch with SFP port in it and 6 rj45 poe sockets.
So if I'm correct I will need a media converter, 2 transceivers and I would use OS2 LC cable with 4 strands.
But now how do I hook everything up ? Do I attach the 2 cameras in the separate building to the waterproof switch and then go with the fiber cable to my house and there hook it up to the media converter .. but then how do I connect it to my NVR ? the nor only has 1 lan port. Do I just hook the media converter to a camera port on the nvr ? Or do need another switch and connect it to the switch together with a cable to my main internet router and then from that switch to the LAN port of the NVR ?
Thank you in advance.
