Need recommendations on PTZ cameras.
FLGator
Aug 26, 2022
99
76
Tennessee
I have the T5442T - ZE cameras setup and have been working for awhile, but I realize I would be better off with a couple of PTZ cameras and would like to know what you would recommend that is similar to these or of even higher quality.
Any advice and recommendations is greatly appreciated.
I currently use DMSS as my viewing application on my mobile device.
The best overall value on the ideal MP/sensor ratio:
Cheapest ones but will struggle at night due to less than ideal MP/sensor ratio:
EmpireTech PTZ494M-25X 1/2.8" CMOS 4MP 25x Starlight IR 4.8mm–120mm Va
Open up the wallet for a great night experience:
1/1.2" 8Megapixel STARVIS CMOS | 45x optical zoom | Ultra light sensitivity | Max. 25/30 fps@4K | Auto-tracking | Perimeter protection | Face detection | Face recognition | Metadata | SMD Plus | IP67 | Dual light fusion | Electronic defog | Wiper
Wow, yeah I was not expecting that high of a price but I understand you get what you pay for. Thank you for the links as well!!
Reactions: JDreaming
Read through this thread first
For a residential home I would go with this, though be aware nighttime IR is weak. As @wittaj says its not on the ideal sensor size.
But with adequate ambient light (street lights etc) its fine.
DO NOT get the smoked lens version
Also most folks find out real quick that a PTZ should be used to compliment fixed cameras, not replace them. You will be disappointede when its not focused on a target becasue its run off looking at some other target.
You can also use fixed cameras as spotters to call the PTZ to a place for a closer look when the fixed camera sees something
Remind me again why?
Buddy got one off of Amazon without checking.
Nighttime IR is weak to begin with, the smoked cover makes it worse
