@EMPIRETECANDY so to confirm Andy, Dahua is stating that if you want to use DSS Pro then you have to purchase the expensive license (about $2800 USD based on
@Graatz EURO numbers he shared) however if you use the NVR it should include all thats needed for ANPR within the NVR ? My understanding from a cam perspective is that the ITC 215 (full HD with AI) do all of this work in camera and therefore you would need DSS Pro (and therefore the license) to use that one directly
however if you go with an ITC 237 which is an ANPR camera with the Algorithm (but does not process vehicle detection / structuring in cam like the 215) then that can output to ANPR processing functionality on the NVR. Please correct where wrong.
@Crazykiller maybe you can weigh in on this as well as I may be off in what requirements the NVR expects (along with license) before it can complete the processing vs the 215 fully in cam ? The ITC cam piece clearly being the biggest requirement but trying to understand the NVR needs as well. Thanks
