Need narrow width POE cam
SoCal
Jul 7, 2016
59
20
Los Angeles
Hi Folks
I am looking for a narrow width cam, needs to fit an area about an inch wide to peep out of. Goes between a fence. Maybe 2 inches room behind on the body size will fit but the lens needs to be small
This will be installed down low to read plates in a back ally
Any suggestion greatly appreciated
:)small cam.jpg
Thank you Sir
Looks like I need to build bigger corner posts and incorporate a few extra goodies, IR cannon
I hate this place my wife thinks I'm loosing it again :)
Hi SoCal,
I was also looking for something which could be easily overlooked and less obvious and this is what I found during my search:
When you are looking for putting a lens in a tighter spot you will be looking at something along the "pinhole" type of cameras... which typically means a bit more pricey and wide FOV - thus limited ID range.
IPC-HUM8230 | Dahua Technology - Dahua Technology
and the ELP ( example listing on amazon - looks like a lot of Aliexpress sellers have something which looks the same )
https://www.amazon.com/ELP-Megapixel-Industrial-Pinhole-Network/dp/B00KA4OGF6
Also possible to build something out of a Raspberry Pi with a Pi Camera.
None of the above seemed to get the image quality I was looking for the price point I was willing to pay, thus that aspect got put on hold and I just mounted a Dahua starlight camera to cover the view I wanted.
Reactions: SoCal
