So I am trying to find a camera option, with either 2.8 or 3.6 mm Lens and mounting position for my doorway. The goal is to keep an eye on packages and catch faces on walk up. Packages are normally left against the bench side wall and window to the left of the door. I know for facial/id 8 feet or lower is best not sure how I am dealing with mounting to the brick. I am thinking turret style cam, leaning towards a 3.6 lens but concerned about the FOV and blind spot of the 3.6 based on the IPVM calc. I could be missing it but I don't think the calc allows you to simulate corridor mode thus my conundrum. Wiring will come from above. The entryway light is normally on motion sensor at night, but we may switch to a LED day/night sensor bulb and leave on all night. I did not think to measure out the height of the light for comparison, but should be about 7'. I'll try to replace the last pic with a daytime one. There will be other cameras out front covering the approaches as well.
My original thought was the right hand corner as viewed facing out of the entryway at about 7' using a 4mm Lens. Plan to run conduit from overhead in the corner to the camera mount position rather then go through brick or deal with the window frames. With downward angel to try and capture most of the space between the left hand window and bench etc. the Space is 8'4"W x 17'D x 9.5'H. I been playing with different lens and FOV on IPVM but I did not have alot of luck narrowing it down. At one point I thought 67d FOV and tilt of 12d with a 3.6mm lens for 5' blind spot. I think that gives me the package view but loses the facial view around the near end of the bench. But I think that would be sufficient for the porch thieves. How does corridor view effect the blind spot? If multi-imagers were cheaper I think one of them would be the ideal solution.
