hi guys
i have installed a wireless network for my home ip cams.
the setup is like this
i have a main 300Mb access point connected to my NVR and 3 300Mb router around the house ,
routers cooncted to ip cams with network cable and the routers connected to main access point trough WDS.
these are my access point configs:
and these are my routers config:
up to this point there is no problem the ip cams connected to routers and the routers to my access point just fine. and the NVR record with out any problem
when you use WDS routers act like a repeater and share access point internet and my problem is that sometimes the routers not connecting to internet and you cannot ping the main access point "192.168.1.1"
but at the same time there is not any problem with recording from ip cams in the nvr! i have to switch the access point on and off to make the routers have internet again. i dont know what did i wrong? can any body help?
