Hey Everyone This is my first post here and hope someone can help me out.
I have a Uniview nvr that I set up will unv cameras and it works great. I needed a few cheap ip cams and ordered a few off amazon, they are ONVIF and they said they will plug and play with my nvr. sure enough, I plugged them in to the poe ports on the recorder and they popped up.
Then I tried to plug it into a poe switch on the same network and now I cant get them to show. any idea what I need to do so I can use the poe switch?
