The title describes the basis of my setup. My problem is that I am having issue making a connection to my IP NVR cameras. I can connect to the NVR device just fine however attempting to use the included VMS Windows based software or Blue Iris software fails to connect to the IP cams I have.
The weird thing is that I can work with the cameras via the Edge web browser but not with other software. My thinking is that I need to have some firewall rule in place to allow connection but I have no idea what that may be?
Does any one here have any experience with the equipment named here or any suggestions I can consider? The NVR has a 16 port POE switch which is set to use a different subnet for the cameras. I get the impression that this arrangement is standard practice, can anyone tell me if that assumption is correct? The subnet used via DHCP by the NVR does not exist in my Edgerouter setup so that is troubling as well as I think routing signal to and from attached cameras will be problematic at best.
Any ideas/advice is welcomed
