got it to work on VLC forgot the 1.Ok, you forgot the ".1." in your string above, I assume that was a typo in your response.
Bring up a command prompt window and type in ping 192.168.1.137
Got VLC to show itNo Luck
Connection failed:
VLC could not connect to "192.168.137:554".
Your input can't be opened:
VLC is unable to open the MRL 'rtsp:/dylan:[email protected]:554/live'. Check the log for details.
thanksI'd go and edit to delete your login/password in your posts, I'll remove it from mine...
Can you put the screen shots again i got cam one up but not 2how do i delete on here
