- Mar 27, 2018
- 6
- 9
So I've spent the major part of the day trying to set this up, I'm going to have to admit defeat and ask for some pro help here. Sorry in advance if what I'm asking is answered elsewhere, I tried to look but didn't find anything.
- I've got a Google Wifi setup, internet comes into the Google Wifi from the modem, another cable comes into the Google Wifi from my old router (which I've made into a dumb switch).
- The dumb switch has my pc connected to it, NAS and now the NVR (Dahua Nvr5216-16p-4ks2E)
- My pc is on IP 192.168.86.28 (gateway 192.168.86.1) so I've setup the NVR to have 192.168.86.80 (gateway 192.168.86.150), but I can't get any response from the NVR when I ping it from my pc..
- Cameras are on 192.168.86.1 to 192.168.86.8 for some reason, not sure why, because I set the default gateway on the NVR to 192.168.86.150 :S. I've restarted several times with the same result.
- I installed Lechange software on my pc (old easy4ip) and it can detect the NVR somehow, but I can't seem to connect to it (it just says wrong password whatever I enter, I obviously made sure I enter the same password as I have selected on the NVR but it just doesn't seem to work?)
This is where I'm stuck, I'd like to get it setup properly so I can get access on my phone as well as externally (via the internet on a VPN setup of sorts).
SUPER appreciated any help I can get here
