Hello all.
I have an array of Amcrest and HikVision cameras in my cam setup and am running BI and recently added a Sunba 405-d20x-4k into the mix. I have several questions and am talking with tech support at Sunba which is slow going and wanted to post to the group to get feedback from other users as I suspect my questions are not unique.
The first 2 questions I would like to start with are:
1. Can you configure the camera by accessing it from its ip address:80 or ip address:8899 or other port?
When I try I get the message that I have to install a videoplay add on. I am using Firefox browser primarily and also tried Edge with the same result. I am not comfortable with using addons or other software to configure the cameras because I feel its a security risk, never quite sure what else may get installed, and am sure many of you who use Sunba and tried to use their software have run into AV and windows messages flagging the software as potentially shady. With any of my other cameras I can log into the cameras and configure as required without any external applications and want to achieve the same result here.
2. How should I configure the Sunba and BI for optimal performance?
I found a thread thats about 5 years old (set i-frames to match FPS) which talks about frame rates and i-frames to match the camera FPS to get a 1.00 key setting but I can not get the key setting to 1.00, right now it sits at 0.17 with about 400.0 kb/s. For the moment I am going to assume the lack luster video quality and FPS/key are related and hope there are some suggestions on how I can get all the settings aligned (BI and camera) so that image quality is greatly improved and performance optimized.
FYI: When I setup the cam into BI, I initially used the Sunba option from the Make/Model drop downs in the Video tab, but when I pressed Find/Inspect it defaulted to Generic/Onvif.
Gladly willing to provide what ever info needed to aid in the discussion.
Thank you in advance for your help and wisdom.
