- Dec 21, 2016
- 1
- 0
I recently bought an "old" NC601 IP CAM for really cheep on ebay (Specs: NC601 - IP Network Camera Technical Specifications). Now im wondering how to add it into my existing CCTV-Network (The other Cams are new models, streaming in MJPG / P2P).
I tried to add it using its IP address and Port but the Software (XEOMA) wont find a stream, even if i add the FFMPG stream path i discovered using an IPcam finder software (IP
ort/stream.av).
The only way to access the stream for now, seems to be with using the IE and active-x plugin
Does anyone have an idea on how i could add the mpeg4 (no H.264) stream of the camera into XEOMA or is there an firmware update available wich makes the cam able to provide an MJPG Stream that i can use?
Plz help me!
Regards
Plz help me!
Regards
