I am playing around with a second NVR, and im having an issue. When i add the second NVR to IVMS-4500 on my phone, it works fine as a local connection. But, when i set it up as a remote connection using my DDNS, thats when things get weird. That second connection will receive the feed from the first NVR!!! Now, both NVR's have their own IP address, and i set up a port forwarding rule in my router for each of them. NVR 1 has an IP of 10.0.0.81, and i forward port 8081 to internal 8000. NVR 2 has an IP of 10.0.0.82, and i forward port 8082 to internal 8000. Yes i have made sure i used the correct port number in IVMS-4500. When i save the device settings, it even reflects the correct number of cameras that are connected to NVR 2. So i know it is communicating with it. My assumption is that the issue is related to the RTSP port. I do have the RTSP port 554 opened up for NVR 1, but my router wont let me open the same port for multiple IP addresses. And, IVMS-4500 wont let me specify a RTSP port which means i cant change it at the NVR. So, how do i go about having more than 1 NVR, and viewing them in IVMS-4500???
