Need help with DDNS
CedarTree
Joined
Feb 12, 2020
Messages
100
Reaction score
16
Hi - I have Comast and since they sometimes change IPs, I've set up an account with no-ip so I can "name" the ip address. When I look at the BI iPhone app, I'm not sure what to put in for the WAN? Right now it defaults to the Comcast numerical IP. How can I put in the alpha name? Also, I have a Unifi VPN setup - so I'm thinking maybe I don't even need a noip account anymore, right? In other words, I can see my cameras on my phone without using the WAN address, just the LAN, and with Wifi turned off on my phone, but with VPN turned on!
wittaj
Joined
Apr 28, 2019
Messages
25,677
Reaction score
50,120
Location
USA
If you are using a VPN, then you put the LAN address in for the WAN, so the WAN and LAN are both your private IP LAN, so what you are seeing is accurate.
fenderman
Staff member
Joined
Mar 9, 2014
Messages
36,848
Reaction score
21,302
You will still need some sort of DDNS service so that you can hit your vpn when your ip changes.
SpacemanSpiff
Joined
Apr 15, 2021
Messages
1,485
Reaction score
2,534
Location
USA
... I've set up an account with no-ip so I can "name" the ip address.
He already has a no-ip account set-up. As @wittaj mentioned, you will continue to use your LAN IP in the config of BI app on your mobile device.
You VPN setup on your mobile device should point to the no-ip dns name you created.
Top
