- May 1, 2015
- 15
- 0
Hi,
I have a DS-2CD2132F-IS and a DS-2CD2032-i camera. Both came with the 5.2.5 firmware pre-installed. I bought these from separate vendors on Amazon.
Both cameras seem to be working fine, in terms of live video but I am unable to get either of them to record to NFS mounts. The NFS mounts (I use separate ones for each camera) are off a FEDORA 21 linux server.
When I create the NFS mount on the camera via the web interface (configuration->adv.config->storage) , the "test" button says that the "Testing succeeded", so I click "Save". Then I go to the "Storage management" tab, and I see the NFS mount listed there. I select the NFS mount, and I click on the "Format" button. This causes the camera to erase every file that existed on the NFS mount (I had some dummy files on there, but have tried it with an empty one too), the "Progress" quickly flashes "Complete", but the "Status" of the NFS mount in the "Storage Management" tab remains "Uninitialized", and the "Free space" says "0.00GB".
I have also logged in to the camera via ssh and I can see the NFS being mounted on /mnt/nfs00 with read/write permissions. In fact, via the ssh shell, I am able to go to the NFS mount directory and I am able to write a file and I can see the file and its contents show up on the actual NFS drive.
I have the same exact problem with both cameras, so I am thinking it is either a v5.2.5 firmware problem, an NFS mount user/group config parameter or it is something else that I am doing wrong.
I'd appreciate some help in resolving this.
Thanks!!!
Camera Info
Model: DS-2CD2032-I
Serial No.: DS-2CD2032-I20150124CCCH50xxxxxxx
Firmware Version: V5.2.5 build 141201
Encoding Version: V5.0 build 140714
Model: DS-2CD2132F-IS
Serial No.: DS-2CD2132F-IS20150331CCCH50xxxxxxx
Output of mount (both cameras)
10.10.10.10:/mnt/camtest1 on /mnt/nfs00 type nfs (rw,sync,relatime,vers=3,rsize=4096,wsize=4096,namlen=255,acregmin=0,acregmax=0,acdirmin=0,acdirmax=0,soft,noac,nolock,proto=tcp,port=65535,timeo=70,retrans=3,sec=sys,local_lock=all,addr=10.10.10.10)
Thanks!!!
Camera Info
Model: DS-2CD2032-I
