Hi, a friend of mine wanted me to see if i can watch some recorded footage from a security camera from where he works. He has access of both the device and the cameras used
He gave me a flash drive containing about 32GB of recorded footage, split in over 100 files of 256MB each, and 4 .bin files (index00.bin, index01.bin, logCurfile.bin and logMainfile.bin)
I've managed to open the mp4 files using VSplayer and the encryption key (i cannot open the mp4 files anywhere else), but the filesystem seems to be all messed up, some files containing over 1000 hours of footage, and ones containing about 5 minutes, and all of them having the same 256MB filesize
Some files i can choose the timestamp, others i can't (just fast forward)
I also cannot merge or convert, Merge tool does nothing and convert tool gives me error to all the files
is there any way to fix this? It's really really important
Just a side note: I don't know exactly the context and specific details, He believes someone ''erased'' the files a few days earlier, i cannot give any more details, but it is really important that we recover footage from January 16th
The recordings (from what i'm able to see) are from between january 4th and January 21, and between Jan 14 and Jan 18 the footage seems to be cut?
But in one file, i can see timestamps for January 16, i just cannot access it. the file is only 25 minutes long, it's very weird
I've attached some screenshots below
