Hey guys, excuse my newbie question, but I have an older DS7616NI-E2/8P NVR running the firmware V3.0.8_140825, which does not give me the option of the new HIKVision DDNS. I am fearing they will close off the old DDNS website soon.
Can I seek your guidance on which firmware version I should be using to upgrade the NVR V3.0.8_140825?
I have done a search and found this link DOWNLOAD PORTAL
If this is the correct firmware I note that there are so many updates since . Would anyone have a update schedule to follow it in steps, instead of going from V3.0.8_140825 to say directly to V3.4.96 build17092.?
I only ask in case anyone on here has done this upgrade before.
Thanking you in advance and your assistance would be very much appreciated.
thanks
thanks
