I'm striking out on searching for these questions in the help file or here. Hopefully someone can line me out.
BI v.5.5.9.3 x64
SenseAI 1.4 beta
Under Blue Iris status, I get Alert cancelled(occupied). I saw in another thread that people need to see the .dat file, but when I go to the AI tab, it has been blank(even when i tried deepstack, this tab has always been blank). I obviously can drag a .dat file, but how do i correlate the dat file to the alert?
Performing a benchmark on SenseAI, i get 2 operations per second? Is that sufficient?
In BI settings > AI, it has the option of instances, is there anything to gain by doing more than 1?
When setting up triggers, do i need to turn off Motion sensor all together? It is current checked, and set with object detection and use zones/hot spots. Will the AI only work in those areas? Do they have priority over they AI, or are they nullified? From camera to camera, i have drastically different detections accuracies, and im not sure if it is because of my various zones/hot spot setups.
Is there an A-Z setup for SenseAI configurations with BI that I'm not seeing, or am i stuck sifting through the various pages about it?
I appreciate anyones time that can reply. I used to be active here, but once I had this up and running years ago, I walked away from it, apparently i missed quite a few events with BI's evolution.
BI v.5.5.9.3 x64
SenseAI 1.4 beta
