fenderman
Staff member
- Mar 9, 2014
- 36,891
- 21,417
Have you followed the advice posted here, with respect to iframe intervals, and receive buffer?I am using Hikvision cameras.
You need to match the iframe interval to the fps...you also need to increase the receive buffer to 20mb..post a screenshot of both your camera video settings as well as your blue iris video config settings. I would also delete the camera from blue iris and add it again...I followed some advice over on cam-it, I don't know if it was the same as offered here. And also from Ken from BI.
Not sure if you figured this out yet.... I've been going round and round with BI support about this. The thing that temporarily fixed it for me was going in each camera options, the "Record" tab, under "Video Compression" change it from "Direct to disk" to "Re-encode with settings...". That fixed the pixelation issue for me, however, I was using "Direct to disk" for a reason and I want to continue to use it, but so far BI support is not able to figure it out.
Uncheck get events with pull point....Here's my screenshots. I did delete and re-add the camera(s). I have not made any hardware or software changes, this started happening after one of the BI updates a few months ago. My system has been running for years without any changes made on my end.
I have not been able to solve my problem yet. Like you my system had been running for some time with no problem and then at some point I started noticing the pixelation/ghosting. I have experimented with different settings and nothing improved. I am going to try disabling direct to disk to see if that helps. I did some testing the other day and from what I could tell the live view does not pixelate its just the recorded version of the clip.
Check use rtsp tinecode..
You have a very low bitrate set...Try using a higher bitrate like 4096 and see if it helps...
Your bitrate was not set a 2000..it was set at 256 according to the image you posted.I believe you are just suggesting things to try here so I am not saying you are wrong but BI support told me to lower my bitrate to 2000. I did not make a difference so I put it back to 4096. I had the same issue at 8192, 4096, and 2048.
