I recently bought this Chinese [1] nvr board with chipset hi3536, model nbd8004-r fw v2.01. I’ve been trying to find the serial ports on this device but no lucky yet. The serial port does not show any data. The same USB adapter works fine to connect to a raspberry over serial, so I don’t think it’s the culprit.
The board with the welded jumpers
The data sheets points the serial port to the connector that I welded. The voltmeter read the following voltages: 2.4v, 3.3v and gnd, from left to right.
I’ve tried all the jumper combinations possibilities but none had worked.
I could not find the original datasheet for the same board, this one is pretty similar though
www.aliexpress.com
38.9US $ 50% OFF|Face Detection H.265 Max 4k Audio Cctv Nvr 9/10/16/32ch 4k/5mp Security Video Recorder H.265 Motion Detect Onvif P2p Cctv Nvr - Nvr - AliExpress
Smarter Shopping, Better Living! Aliexpress.com
