My wife and I own a few rental homes. We're currently working on one after a tenant left. They had installed a DIY ADT Blue system and left most of it at our rental. I've removed everything but the problem is the doorbell camera. I'm really not sure what all they modified with their install. I removed the camera and reinstalled a basic doorbell push-button, but nothing worked. I opened the chime box and nothing is wired to the chime. The original wiring is wire-nutted to other wires that go back into the wall, and I'm assuming into the attic, so that explains why the chime isn't working. The strange thing is that I have 18-20VAC at the chime wires whether the doorbell button is pressed or not. If I'm thinking correctly, their should be no voltage at the chime unless the button is pressed, but I have voltage there constantly, so I'm not sure what they did. I guess I'm going to have to go into the attic and try to find the transformer and whatever else they may have changed up there.
Any ideas what may be going on with it or how an ADT Blue Doorbell Camera is wired that might cause this?
Thanks.
Thanks.
