Lady yesterday driving like an idiot made a lane change into my son's GTS and denied she made the lane change. Same thing happened about a year ago and the dash cam video settled that dispute real quick. We went to play the video from his Mobius Actioncam and no recent video flies are showing up on the SD card. The camera was flashing like it was recording normally, but there was some problem. I think there is a small chance the video data may be on the card as I ran a data recovery app that recovered a lot of files. However, even the .MOV files it recovered will not play on standard players like VLC and Quicktime. So I think the files are corrupted. I discovered that the battery on the dash cam failed so the camera has been shutting off without properly terminating the video files. Not sure if that caused the problem or if the SD card failed. I've had 2 of the SanDisk memory cards fail in my dash cams so far in the last 2 years so that could also be the issue. In a prior SD card fail the cam looked like it was working normally but nothing was being saved and I could not format the card.
Does anyone know of software that will do a brute force playback of whatever you give it? I'm guessing there has to be something out there that you could specify what codec to use and it would play back whatever data is saved. If only a portion of the video file is damaged, maybe we can recover the lane change.
Would prefer Mac app but Windows is also ok. I tried Yodot MOV Repair for Mac and it wasn't any help.
After this experience, and mine where I found that my SD card failed and it looked like the cam was still working, I plan to swap out my cams for ones that have a display so I can check more often if my cam is actually working. I typically would check my dash cam videos about 1x per month to make sure working. With a unit that has a video display I'd check much more often as I would not have to remove the memory card to playback on a computer.
Damage to GTS not too bad - it has about a fist size dent on the 1/4 panel. Nothing structural but if the repair shows up on a CarFax it could have a significant hit on the car price when it is sold.
