likely an ip subnet issue. The first thing you need to do is login to the cameras own web interface. If you cant, blue iris cant.I finally have all my components. Cameras, poe switch made my own cables and purchased blue iris. Got everything connected and can't get the camera to connect to blue iris. It will not pull the camera up when I try to find it. I'm doing something wrong. Or I don't have it hooked up right.
I started with IPC-COLOR4K-T180. Switched over to a icp-t5442tm-as 3.6mmWhat cameras?
You need to set the cameras up in the camera web gui before you can put them into BI.
For example, if you bought all Dahua cams, they all come with the same IP address of 192.168.1.108 and you have to manually change them to match your IP subnet and make each one unique before BI can see them.
Then in BI you type in the IP address, username and password of the camera and hit find/inspect and then it will find the camera.
So if they are all plugged in and you didn't do any of this then they are all IP conflicting one another.
