- Jan 4, 2015
- 10
- 0
Hey all,
Just got into POE/security cams. I got the camera working and set up to the NVR. I can access through my android phone if I am using my home wifi which the camera is set up through the NVR. Another problem I am having is when I try to access the admin panel for the NVR via mac it doesn't let me login (probably a plugin issue). I can access it via my internet explorer on my windows 8 laptop.
My set up as follows:
My cable modem SB6580 modem has an ethernet feeding the NVR then the NVR is feeding the camera. (can someone please send me a screen shot on how i should have port forwarding done on my SB6580..the modem has built in wifi so I can access the port forwarding via logging into the modems settings.
Problem I am having is I can't access my no-ip.org dynamic DNS address if I am using my cell phone LTE or any internet outside my home's wifi network but it works when I am using the home wifi which the modem/camera is setup thru.
Any tips or walk thru area I can research how to set it up properly will be appreciated.
Thanks
Thanks
