I have a POE system that I bought from Backstreet Surveillance. I have a camera that I want to have on only when my (DSC) home security system is armed.
I have most of it figured out on the alarm end. However, I need to turn off the camera by powering it down. The simplest way seems to be to cut the POE power to the camera.I will use another power supply (Wall Wart) with a smart switch to power the camera when I want it on/off.
I opened up my CAT6 Cable running to the camera and cut what I understood were the POE wires ( Brown and Blue Pairs 4,5,7,8). This leaves data on pins 1,2,3,6 intact. I've verified that the "correct" pins are cut with a circuit checker.
Anyhow, with the pins cut and no other power supply pugged in, I'm still getting my live camera image!!
I will call Backstreet in the morning. However, I thought that I'd check here for help:
(I'm a newbie here.... please be gentle)
Thanks!
- Why do I still have a live image with the POE wires cut?
- Any better suggestions on how to switch the camera on and off?
Thanks!
