About 8 or so years ago I installed an ip based home camera system with the 2mp starlight 5231R-ZE cameras which were considered best at that time based on information from this forum. Have been pretty happy with the system, however, I'm sure technology has progressed since then, so I have started researching this forum again to determine the current 'go to' camera for a reasonably priced system for my son's property. But I can't decide if I would be better getting color night time cameras using white LED's, or sticking with B&W with IR LED's as I currently have. To further complicate matters, my sons property is very different to mine, much smaller - the maximum distance required to view and get good detail of human subjects is 6 meters, and that's only for one camera, the others are only 2-4 meters. I am thinking possibly the color night time cameras with white LED's may be better, but short of purchasing and trying them out, I really can't be sure. He also has some sensor lights which would help in some of the areas with additional lighting, but not all areas. There are street lights for illumination however someone entering the property will be backlit so can't rely on the ambient street lights for decent id.
So I would appreciate any advice on the current crop of night time B&W vs colour cameras at relatively short distances (<= 6M), with poor illumination (for the areas that aren't currently well lit with sensor lights) - which give the best image quality for moving subjects at night time?. And is there a current 'go to' in each? Or should I go for the camera model's that have both IR and white LED's and decide which way works best, or is that a compromise solution? In any case, no need for very fancy software other than zone intrusion detection that my current cameras perform well enough. I think 4MP with 1/1.8" sensor, and preferably vari focal is roughly where I will be looking at starting.
Thanks in advance.
Thanks in advance.
