- Sep 7, 2014
- 9
- 0
Hello all!
I'm the new guy that decided to setup an IP surveillance system in my home to replace the aging Logitech Wi-Life system that I currently have in place.
A little background: I'm okay with computers and am not afraid to get involved with these types of projects. I've done some Cat 5 cabling, serial cabling, phone cabling, etc. When it comes to networking, though, I guess I was absent that day.
I've had my wife's car broken into a couple of times and our mailbox knocked down half a dozen times over the past few years, so I decided to pick up a Wi-Life system in order to help identify the perpetrators. Since installing this system, I was able to nab two of the people that knocked over our mailbox and was able to see the vandal that ransacked my wife's car.
After not being able to clearly identify the freeloading asshat that vandalized my wife's car, I decided to upgrade our home's surveillance system.
For now, I'd like to start with a couple of cameras to replace the ones I currently have in place, but, in the near future, I'd like to add a couple of cameras at a time until I reach a total of eight cameras covering the front, sides and rear of our home's property.
After much reading on this site and others, I decided to start purchasing the items necessary for this installation.
Here's what I have picked up, so far:
1 - Hikvision 2332 turret
1 - Hikvision 2032 bullet
1 - HP Procurve Switch (Managed 8-port POE w/gigabit uplink)
1 - 1000' spool Cat 5e ethernet cable
50 - RJ-45 Cat 5 connectors
I already have an i7 PC hooked to U-Verse's Arris NVG589 4-port modem/router. I'm using this PC for the Wi-Life system, so I'd like to do the same for this system, as well. I also have the crimper, cutter, and Cat 5 tester from my previous installations.
After receiving the Hikvision cameras, I ran SADP and assigned each camera its own IP address. I'm using 192.168.1.201 for camera one and 192.168.1.202 for camera 2. The modem/router is 192.168.1.254, so I used that as the gateway address. For port forwarding of the cameras, I assigned 8201 for camera one and 8202 for camera 2.
I assigned 192.168.1.200 to the HP Procurve switch, which gave it a static IP address, not an assignable one.
Here's how everything is hooked up:
Starting from the end, the two cameras are hooked up via ethernet cables to the HP Procurve switch (ports 1 and 2, but that supposedly doesn't matter).
The HP Procurve switch is hooked up to the U-Verse modem/router via an ethernet cable from the uplink port (port 9) to one of the four ports on the modem/router.
The i7 PC (192.168.1.65) is hooked up to the modem/router via an ethernet cable from the LAN card to one of the four ports on the modem/router.
I entered the Firewall section of the U-Verse modem/router and found (after a lot of reading) that there are two sub-sections in here that I should be modifying. One is "NAT/Gaming" and the other is "IP Passthrough".
I have tried every conceivable combination in these two sub-sections and I always get one of two results:
One result is that I can "see" the cameras through a browser by typing in each of their individual IP addresses. I can also open up SADP and see them there. The problem is, then I can't access the NVR software via my external IP address. Using the open port check tool, port 80 is closed.
The other result is that if I change things in this Firewall section, I'll then be able to access the NVR software via my external IP address, port 80 is open, but then I can't access my cameras with a browser or through SADP.
I have loaded Milestone's XProtect Essential and the Hikvision NVR that came with the cameras. Neither one of these software packages have been able to access the cameras via their respective clients, either locally or via the internet.
I've been at this for a few days now and have finally hit the wall of frustration.
What do you all think I'm doing wrong and is there a website that I can go to or a post that you can point me to which would explain an A-to-Z of what it is that I need to do in order to get this surveillance system up and running? I know that it's probably something basic that I'm missing, so any help would be greatly appreciated.
Thanks in advance for your time and efforts!
Have a good evening,
Vic
Vic
