Hello Everybody
I purchased a no name brand Network DVR I can view the feeds from the web browser without issue, and If I insert the DVR's IP address into a android app called IP cam viewer it allows me to view the feeds as well.
The app allows me pick a channel between 1 and 4 so that I can view separate feeds. However in BI when I select generic profile and use the same IP/port numbers I get either IO error, no signal found or a 404 error. I do not see any
way to select a channel in BI so I assume this is part of the problem. I have tried for about 11 ours in total using every method I could find online and I simply cannot view the feeds. I would appreciate any help I can get at this point!
Thank you for reading!
Lynton
Lynton
