witchboard
Good suggestion - I will call monoprice since I do not see the 500 boxes available.
It's because you are shopping for Cat6A. Is there a reason you need Cat6A vs regular Cat6?
This said, Cat 6 is more than enough now. I am just overwhelmed at the STP cable and needing to earth ground every single camera. This just seems overkill to me and I would need to do this myself and my time is really valuable to me now. ..... I can use surge protectors at the POE switch and NVR but seems like an ordeal to earth ground every single IP camera - it costs about $40 bucks + time to do this all for a $120 camera.
He said if anything gets fried or if I have any problems, he will re-install for free.
He says ......most lightning would go through the electrical system in the house which is already grounded.
Understandble. At the very least, I would install a Ubiquiti Networks ETH-SP Poe External Surge Suppressor between the POE switch and the NVR and ground the ETH-SP properly.
I'd ask for that in writing. If GA is anything like AL (and it is), it's not a question of IF something will get baked by lightning, it's WHEN.
He is VERY mistaken about that.
Or, just go UTP riser rated and use surge protectors at the critical points?
Yes, at the very least.
Also, my PC is on an APC battery backup and there's a Ubiquiti ETH-SP protector on the Ethernet before it comes into my PC.
How/what do you ground your ETH-SP protectors to?
