Hey all,
I've been doing some reading on this forum, as I'm looking to install some IP cameras in my house. Problem is, while most rooms in the interior of the house are wired with CAT5e, the exterior is not.
The company that originally wired the house when it was built say they can't do it because there are no paths for them to run the wires on the inside, and they refuse to run wires on the outside of the house. I've got another vendor coming out next week to see if its possible and to give an estimate, and waiting on replies from a couple others. My plan, if possible, is going to be to build a new desktop (or re-purpose my old i7 tower), and run BlueIris on it to handle the recording.
Now for the cameras...of course, being in IT, my preference is to buy a PoE switch, and run CAT6 out to the camera locations. IF that is not going to be possible, then that either severely limits my options, or puts the brakes on this project completely. From the reading I've been doing here, wireless cameras are complete pieces of crap that should not be used for any recording, unless you just want to look at the live camera feed from time to time.
If running new CAT6 lines isn't going to happen, is powerline networking an option at all? I mean, the cameras still need power, hence my preference to run CAT6. I read someone post that powerline networking is a much better option compared to wireless cameras.
But the one thing I haven't been able to find an answer to is, do powerline adapters work outdoors? Keep in mind, I live in Canada, where temperatures in the winter routinely go down to -20 or -25 degrees Celsius. Extremes would be -35 or -40, but that's more rare. I just did a quick Google search for powerline ethernet, and I found a TRENDnet unit on Amazon, which according to the specs, can be stored at -20C, but it's minimum operating temp is 0. Are there other models that will work outside in the winter?
Also, I've been reading here that Foscam units are mostly junk, and Hikvisions appear to be the best bang for your buck. Last question...how do you tell, when purchasing a Hikvision camera, that you're getting a real US/English version, and not just a Chinese camera with hacked firmware? Some of the listings I've seen, particularly on Amazon, are pretty ambiguous in that regard.
Any thoughts?
Thanks!
Any thoughts?
Thanks!
