- Oct 13, 2014
- 10
- 0
Hi everyone, I’m new here as I just registered on the site. So I have some questions that I hope you can help me with.
I’m looking to install some cameras on the outside of my house, thinking about 6 to start out with, 3 for out front and 3 out back. One of the three in the front and back I would like to cover the front and back doors and the other four to cover the front and back of the house/yard. They will be installed on the outside of the house under the roof on the second story. The two covering the front and back door will be installed right above the door on the first story roof. I would like them to be HD quality, looking to spend no more than $200 on each camera and less would be better.
I would also like to know what software I could use for this and what type of computer specs I would need. I would like to have them record 24/7. I can build and wire everything myself or I could buy a kit if that’s the best way to go but I doubt it since I have found it’s usually cheaper to build your own system.
So what do you guys recommend for cameras to cover the yard and the front and back doors and for the computer software and hardware. I would also like to power the cameras with CAT 6 if I can.
Thanks
Thanks
DS-2CD2032-I
DS-2CD2332-I
DS-2CD2532-IS
